Also will the front airbags still work without the seats being fitted?
When you say put resistors in, is it as simple as soldering one end of the resistor to the one wire and the other end to the other?
Yep they will regardless or the light being on.
As Middo said Renault can sort of switch the seatbelt off but thats for diagnostics not long term use realy.
meh, just go to maplins, get 2 resistors, (20p max) and double over the ends, and poke em into the connectors, tape them up job done
oh and Clip is renaults diagnostic
if it trophey seats then you can alter the settings using clip, most renault dealers wont do this though.
