PH1 172
How have you mounted these for track days or daily look if thats your use?
I knew I had to make the hole slightly bigger on the tow strap so that the correct bolt size that screws into the tow eye hole fitted through but I have come across 2 problems:
1) The bolt head barely passes through the hole in the bumper, which means there is no room for a socket or spanner
2) The tow strap has no where to pass through the bumper.
Do I need to cut away some of the square panel where the tow eye hole is cut or is there another way?
