For a fast road car personally i'd have 1.5 degrees of neg. camber on the front with 5-10 minutes of toe out. I'd leave the rear as is or zero the toe in on the rear also, there isnt a lot more point in going madder than that. Will never seek the limits of grip/the car on roads anyway.
1.5-2degrees neg camber on the front (2 degrees gets a bit fun on normal roads though lol) and 1 degree of toe out for a bit better turn in
That's what I'm gonna get mine set to for brands hatch and see how I get on
That will also be very rear happy, probably too much I think! Dont think even the Burpspeed guys had that much and they couldn't keep the rear end straight!
I have run -2.5 on the road and found it too light at speed and too twitchy. You had to have very steady steering inputs. The turn in was incredible, it was hard to believe it was the same car after fitting camber bolts.
I am now running -1.0 and it is a good compromise, but it could do with being at little sharper so it is going for some more adjustment.
I think -1.5 would be perfect for the road, but it is personal preference, it depends how exciting you would like the daily drive to be.
Will I need camber bolts for adjustment or is there camber adjustment as standard? Car is currently running way too much camber I think so wanting to dial a bit out tbh!
Running gaz coilovers if that makes a difference, buy no camber bolts
My car is running -1.0 with standard bolts, i thinking this is down to the amount the front has been lowered. I used bolts when it was running -2.5. Worth buying a set for £20 and having them with you. Most geo places will charge more than this for them, if you don't need them,then just sell them on.
If i have mine set to -1.5, i think the bolts will need refitting.
Get a PROPER tracking set up done on it, camber too, and then see what you think. It transformed mine. Corner weighing is quite extreme IMO.
Seriously, I thought mind handled brilliantly before, had the tracking and camber done, it was like a different car, the previous "limits" just weren't there any more, I found I could carry so much more speed is was unreal (and a little scary).
