Fattys alternative and accustic valve
Car  renault clio 172
I have the fatty's alternative induction set up would i need to replace the accustic valve with another pipe to feed the filter has its the only pipe i have feeding the filter at the minute
No it can all be removed. All you need to do is bung up the pipe that goes from the inlet to the acoustic valve, otherwise you'll have an air leak/high revs.
