Faulty electronics?
Car  182 Cup
Hoping someone can help!
I was just popping the shop when I noticed my headlights kept going out, when my lights are off and I push the indicator stalk to put my right indicator on my main beam headlight comes on. It seems to happen every few minutes.
there are no fault codes, no warning lights & the same headlight I replaced 2 weeks ago has blown already, could this be th issue?
it looks like the brake light in the spoiler has stopped working also, it's an 06 plate mk3 1.6 dynamique S
thank you!
Early clio 3 have serious problems with the UPC getting wet because the cover seal is misaligned.
Take off the cover and there will be moisture in there I'm betting.
You could fit it yourself, it's not hard at all. It will start and run With the new one but the alternator type will need to be programmed into the new one.
