Fecking Side Bullets! Help? (Pic)
The Boosh!
ClioSport Admin
  Elise, Duster
* iv done a search and nothing really answeres my question so:
Decided to spray the other half of my side strips as i only did the back ones so i could practise.
The time hascome to do the long front bits. managed to get themoff fine. i want to take the bullet off so i can do it seperatly.
I have managed to do the two circle bits as they just pop off with a screw driver. its the one in red im struggling with?
i cant work out how it pops off. iv been messing around with it for about 20 mins now and i dont want to force or break anything.
can someone help?
thanks
/Luke
  Never above 25mpg
They just lever off with a screwdriver, theyre easier to get off than the damned side strips lmfao
press the middle 'button' thing on it down and kind of lever it up... it's hard but with a bit of force you'll get it off
  mk2 slow. . .
the plastic on that bit is slightly softer, so work in at the side, get a bit of the flat headed screwdriver under it then push it between the clip on the bullet and the bit on the sidestrip, then just push it along slowly, it works exactly the same as all the other clips except the plastic is softer for some reason.
  BMW M135i
Put the strips back on the car and just pull the badges off with your fingers. Takes 10 seconds tops.
  FTO GPX 2.0 V6
I used a screw driver today, was a bit of a pain, but lifted the lip bit of the clip and pushed and it came lose.
  M235i / 172
Yep, just pulled them straight off of mine. Youve gota really pull them though, dont be a girl and think they will break or you wont get them off mate.
The Boosh!
ClioSport Admin
  Elise, Duster
hehe no vein its not that - i diddn't want to snap anything and have to mess about gluing them - plus there going all the same colour (black) with white lettering so figured not much point in taking them off :)
  Never above 25mpg
ah right ok!! My strips are in primer atm! side bullets were the first things i took off before anything ;)
aucky
  N
How do you get the side strips off?
Im too scared of snapping one of the 102023 plastic clips that holds my car together lol.
