Alright so I've had my Clio for just under two months now. It's pretty great, In fact I love it though there is a few problems I'd like to try and fix, with hopefully the help from you guys. After looking on the forums I've found various scenarios for a couple of my issues. But I'd like to nail it and get them fixed before my winter service!
Info: Clio 1.2 16v 02 plate Expression, so hasn't got climate gor anything fancy lol
They're not really problems, More so issues. No negative effects as I can tell. But they're just there and they've got me worried it would cost a bomb come winter service.
1. My outside temperature is reading an astonishing 42'C! It would be perfect if it was... But it's more like -1'C! Possible problem with the nipple thing on the mirror or wiring etc..??
2. Well... Car starts perfect first time. Every time. I always wait about 10 secs to let thw fuel pump through and wait for he lights to go out before turning it on. Only when it does fire up.. The revs jump slightly up and down a couple of times between 700 to 1100 revs, up and down up and down, after a few mins it'll settle at 1100 then gradually pull down to 700/800 revs where it'll sit nicely, can't hear it run when you're inside the car lol. Is his normal????
3. The engine temperature gauge - it will never reach up to the half way point and if it does it will then just go back down to the quarter point (only half way up to normal operating temp) up and down. A couple of times I've say there nd just let it idle to get to half way, but it would just drop down again. Even after running 20+ miles in 5th gear at 60mph! Sometimes it is fixed by running a journey, stopping for a bit then starting again. (noticeably when I'm shopping etc..)
4. There is never really any heat coming from my heaters. The fans are moving perfect. After say 20 mins I can run the fans on hot on the slowest fan setting and it will blow a bit of heat. Quite hot, but when ever I turn the fans up faster the temperature of the air blowing out just goes colder and colder. I'm thinking that this is some sort of heating element issue? Like... Blowing hot under no air passing past it but gets blown cold by the fast air etc.. If you know what I mean lol.
5. I'm wanting to change my radio from the crappy custom kenwood that's in now to a bluetooth/cd mp3 player phone thing setup. The stalk is not currently working, but how would I go about getting this working when income to change the radio to my current as I'd like to get everything working was it should. Would I need to buy some kind of wire extension ? As I'm thinking the guy who had put this radio in might of just not bothered to get it working. Or just couldn't with this radio.
Thanks for reading and im sorry for making your eyes bleed with ma wall of text!
Hopefully someone can help! Service soon and I think it may be an expensive one !!!!
Craig.
Craig.
