Clio 182 no brakes
Car  Clio RS200
I've just changed the front and rear calipers along with some hoses. I can't seem to get a brake pedal when the engine is running, however when it's off the pedal will pump up. I've bled the brakes using Eezibleed and fluid is coming out without air, yet I still can't get a pedal when the engine is running.
Hopefully someone can identify the issue ad it's got me baffled.
Yes that’s what I was wondering. Would that be enough to explain fluid coming through but no pedal with the engine running? Is CLIP the only solution?
The thing is there is no brake at all, pedal just goes to the floor when the engine is running and won’t even pump up to get a pedal. Is it possible there could be another issue?
I’ve got brakes now. Bled them again this afternoon and several big air bubbles came out of one of the front callipers. The brakes don’t feel that sharp still when I road tested the car. How will I find out if there is air in the ABS pump?
