few questions
My Gimour foam master arrived today with some snow foam:cool: Just a few quick questions, how much snow foam do you put into the bottle? Does it need mixing with any water? hot, warm or cold? Also what setting does it need setting at? A, B, C, D, E or off?
What Wax/ products am i best to use which will get me a really deep gloss look which is long lasting.
The colour of the cars are Inferno orange cup and a 449 blue williams.
thanks:cool:
Some use Snow Foam neat, some mix it with water. I have the older style Gilmour which tells you on the bottle which each setting gives you ratio of product to water. Play about and see what works best.
When using neat product in there I use the lowest setting, when using a few inches of soap topped up with warm water I use on the highest setting.
For deep gloss the main area to look at is the prep in itself and in the polishing as this is where the main look comes from.
thanks for the help, on the snow foam bottle it says normal concentration 1-5% hot or cold water. the gilmour settings are 1-128, 1-64, 1-32, 1-20, 1-10.
I dont use the Snow Foam so no advice on that itself.
Settings sound as my older style one, 1-128 for neat product, 1-10 for an inch or so of shampoo topped up with water.
