Few questions..
Car  Clio 182 Cup 2.0
Iv just replaced my rear discs and pads and then took my car out a run to see what like!! As soon as I left my drive, the traction light kept flashing and I wasnt able to gain any acceleration whatsoever. I then turned the traction control off then (traction control light on dash) and I was able to drive as normal afterwards. However the ABS and SERV light then came on. Im guessing I've missed something out whilst replacing the discs and pads?? Any ideas...
what are the abs rings?? the sprocket on the back of the discs? If so.. im guessing thats where iv gone wrong
Have the new discs you fitted got abs rings?!
^^this
Also was the little spacers refitted behind the discs??
These are ABS rings should be fitted to the rear of the disc
you can remove them yes but will most likely get damaged plus they need positioning in the right place on the new disc. where did you get your discs from?? non renault if so the bearings shall fail faster fan normal
