fiitting brake disks
Car  RARE Unmolested Corsa sxi
i should have two new front brake disks for my clio 1.2 16v delivered tomorrow.
i am contemplating fitting them myself, but was wondering if it is easy enough.
i theory it seems like i just pull them off and swap them over, but im not sure.
do i need to take the caliper off or can i just move it out of the way?
thanks.
ps, is there a guide on here?
if you search you should be able to find a guide.
its not that bad at all, but im too lazy and got my personal mechanic edde to do mine lmao
Its the same as the 172/182 realy just bolts are slightly different.
Change your disks and pads though since to get to the disk you've got to remove the caliper anyway. Plus why do your think your disks are worn not your pads? Unless you run DS2500/300/PF97 you need to chnaging pads most lilky.
The link is in here to doing the 172/182 you could have just done a search for changing brakes pas I've written it enough times.
http://www.cliosport.net/forum/forumdisplay.php?f=42
