Filled up with fuel. Light still on? :S
  Freetrack&Monaco 172
No ideas at all, your french car has developed a new feature!
....However, what does your fuel level say, is it still on the bottom of the dial?
  BMW M135I
just drive it about, it will probably start working again soon, my brother works at a petrol station and some car owners try to say they put petrol in and it hasnt gone up but it just needs to filter through first and they never return when they do
  E46 325ci, ZX10r E9f
had a hire car couple of years ago and filled it up before taking it back, was about to turn into the hire place and noticed the fuel gauge was still on empty ( 2 miles from petrol station ). drove back to the petrol station to say that their pump cant be working but they said it was and to drive some more............after a total of 5 miles the needle went up to where it should've been
  Clio 182
Had this once in my Laguna and once in the 182. I had left the ignition turned on and the fuel i put in did not show. Just went and put £5 in and it went all the way up.
Turn key and the trip says "oil ok" - unless its no of course.
If you then press in the reset button it gives an indication of how much oil you have with small squares. Not sure how acurate it is tho.
  Renault clio 172
i had a brandspanking astra vxr nurburgring which would do it every now and again like everyone has says just drive around for a while maybe throw it round some corners lmao it will soon be back to normal!?!?
