Fitting a CD Changer
Car  Peugeot 306 HDi
I am about to buy a CD Changer for my Dynamique and wondered if someone could tell me how to fit it; how to pull the stereo out etc and where to run the wire to get it behind the dash?
You need to put either coat hangers or you can get a tool from Halfords to remove the head unit, they go in the four holes in the front of the head unit and then it releases it.
You run the wire around the edge of the foot well and under the plastic on the outside, it then feeds into the back of centre console and connects to the headunit, I think it will only go in one of the ports at the back.
Thank you again Ben! Lol. Just taken the HU out and it seems easy enough. Cheers for your help!
No problem, when it's connected use the steering wheel stork buttons on the top to change to the changer and the button on the bottom to change disc.
