Fitting a Quick Shift
richard691
  Twingo RS133 & 172
Fitted a B&M quickshift to my 172 ph2 today, thought it had all gone well until i tried selecting reverse. Don't understand why i can't select reverse, all i know is that when you pull the sleeve up to select reverse, the underside of the gear stick hits the right side of the plastic housing. Has anyone else experienced similar problems?
  RS RIP
Some have a cable-activated rear shift action. my shifter when pulling up on the lever just lifted OVER the plastic so reverse could be reached. Sorry not much help
Oy yeah; how come yours touches the right side (bottom of stick) of the housing ? when i select reverse it's on the left ?
richard691
  Twingo RS133 & 172
Need to know how to get round the problem. Can't really drive the car with no reverse :(
richard691
  Twingo RS133 & 172
Doesn't solve the problem though, really need to know how to fix this.
  Clio 172 Ph2
release all the way the shift knob and try to engage reverse gear.
if you can engage reverse then you have to leave a little bit higher the shift knob by adding something between the shift knob and the shaft.
  133, 182, Kangoo 182
Had problems with mine but I don't know how it was fixed. Wouldn't go into reverse if I had it pushed all the way to the left, had to bring it back towards center ever so slightly before it would move up into position.
richard691
  Twingo RS133 & 172
Have already tried this, really need to sort this out now. Starting to get really frustrated :mad:
Yanoo
  Clio Williams
It's shame that such an expensive part doesn't work properly and the manufacturer does not solve this common problem. I would do the followings:
First: get off the gearstick gaitor and check the sleeve: when you lift up the sleeve, the bottom of the reverse-lock sleeve must be higher than the top of the plastic gear lever housing otherwise you cannot (pre)select reverse. If this occurs then:
1, determine the reason of the problem: Is it caused by the too short sleeve groove or the wrong position of the gearknob.
2, if it's caused by the too short groove (that doesn't let to lift up the sleeve enough high), then: you must cut / grind a bit of the sleeve bottom
3, If the gearknob sits too low: the gearknob is threaded -> put a washer onto the top of the stick -> you won't be able to screw on fully the gearknob -> you will be able to lift up the sleeve higher (in this case you should use high strength thread locker)
If the sleeve is fine, then:
1, check the rubber gaitor (cube shaped) at the gearbox side: whether when you(r friend) select(s) reverse (in the passenger cabin) the gaitor enables taking up the right position of the selector arm or the gaitor seizes between the gearlinkage and the selector arm making impossible to select reverse.
2, get off the cube-shaped rubber gaitor at the gearbox side and check: whether the (long) gearlinkage hits the gearbox housing when it's in reverse or the head of the clevis bar touches the selector arm. If this occurs, you have to grind the parts a bit.
3, disconnect the elbow-joint at the gearbox side. Select all gear by moving the selector arm by hand. In all gear you have to check the clearance of the small gear linkage: Can you turn around the small gear linkage around its axis? If you cannot then the diameter of the bigger ball is wrong. If you can then you have to realign the clevis bar... that can be a real pain.
Hope this helps.
  Clio T 314hp c43 AMG
when i fitted one on my last 172 i had to shave some of the plastic away where the reverse selector slides, then add plenty of grease, it got better after using it for a while, was one of the best things i did to my last clio, a great mod.
richard691
  Twingo RS133 & 172
Sorted lol, black plastic trim getting in the way of reverse underneath car. Works a treat now. :clap:
You got any pics of said 'trim' mate? I've been having this problem witg mine for a while now and don't really want to have to chop away part of that plastic so the reverse selector can get over it.
richard691
  Twingo RS133 & 172
I don't sorry mate, have put the heat shields back on. Its easy to spot anyway its the only black strip on the underside of the gearstick housing, easily unclips when you wedge a screwdriver in there ;)
