Fitting brake discs
similar thing mate, before you remove calipers, get a mate to stand on the brake pedal whilst you undo the 2 torx screws locating the discs
caliper is held on by 2 x 18mm bolts
easy peasy
easy peasy
Pussy lol ;)
Just hold the disc with one hand and undo with the other
there's an easy way to do things, and then there's Lunners way of doing things
I can't be in the car and at the wheel at the same time, and you know i ahve no friends :dapprove:
stick it in gear, or stick a screw driver into one of the vents on the disc and lock it against the caliper
Again far too easy, i like to do it the hard way.....although those are good tips for removing the hub nut if you forget to loosen it while the cars on the ground:o
