Fitting CD changer?
  182
My ph2 172 didnt come with a cd changer under the seat and i want to fit one.
How difficult is it to do?Any drilling needed?
very easy mate. just plugs stright into the back of the head unit. Only pain part will be to run the wire without seeing it. When it comes standard I think the wire runs under the carpet and comes out under the seat where the pretensioner wires are. Apart from that the unit is screwed to the floor with 4 bolts.
i have a cd changer in my Clio and wondered if i can connect it to my JVC headunit or does it have to be the standard clio headunit.
need to take the dash top off, but its no big task.
I retro-fitted the changer to my 182, and fitted it under my drivers seat.
OEM head unit only, even though the changer is made by alpine it only works with the renault HU.
why do you need to remove the dash top? You can thread the wire up the back of the centre console no? thats what I did with the tunepoint (would suggest getting this over the CD changer to be honest).
It's easy. No need to take the dash off at all, can thread the cable through under the glove box.
Takes 15 minutes!
Bump for this as I might have a go at this tonight.
Does it bolt to existing holes the seat uses? I was actually thinking of fixing it under the seat with strong velcro.
I'm assuming the pax seat has to come out, or is that not necessary?
in my ph1 172 there was no cd changer so i bought one wit the cable.
in the ph1 anyway they go under the driver seat because there is a plastic thingy under the passenger.
also no need to take the dash off just the plastic thing right inside the door run the cable up there over the steering wheel and ta-da
Bracket and changer replaces the underseat passenger tray in the car.
I ran the cable underneath the carpet, carpet was stuck in the middle under the ash unit, cut it in half, pulled the carpet down and ran it through and pushed it all back together, then pulled it along till there was a slit in the carpet, work perfectly.
