Fitting hids
  Clio 1.2
Came to fit my hids and took apart the headlight and got onto fitting the two spade connectors from the headlight bulb block to the hid positive and negative, does anyone know what side is which the wires from the block, their are two brown to one side and one yellow to the yellow, which side is the negative and positive help please!? :) thanks in advance
get a multimeter and test it . hold 1 pen to a cable and the other to a bolt on the body off the car (mass) or the negitive on the battery and then put your lights on . when you have a signal you have the positive . ( think the brown ones are mass. not sure)
