Fitting HIDs?
Car  dCi 100
I really don't want any of this 'its illegal', 'don't do this dont do that'.
I've gone to fit some HIDs to my 2004 dCi dynamique but cant find anywhere to plug the spade connectors.
Any help/pictures would be greatly appreciated.
usually you have the bulb, then a ballast.
Bulb will plug into the ballast, usually by a 2 pin plug and then a single pin plug.
Ballast plugs into the existing wiring loom/existing bulb holder with the spade connectors.
for example, if you have H7 bulbs, there will be two wires that connect to the back of the bulb, unplug these two wires and stick the two spade connectors into these two wires. if it doesn't light up, swap them around.
I have the ballast etc. The whole kit basically. Ive fitted HID kits before to my 106 and a friends corsa.
Bulbs are plugged into the ballast but I cannot see any to connect the spade connectors.
I have H1 bulbs and there is just one plug which goes into the orginial bulb nowhere to put the spade connectors.
Thats exactly what I asked not to be said. I had these in my 106 and there wasnt any problems so please keep your opinion to yourself.
Just checked and they are not. Seriously dude I'd just get some xenons from a higher model. Less hassle and not nick worthy, especially given they look shite in regular lights anyway.
Just giving you some help. HID's in reflectors might be ok for you, but for everyone that sees you, will think you are a prized dick!
Requires auto wash wipe and self leveling and the correct headlight reflectors to be legal. Also cars with these cheap kits fitted in the wrong head lamps look terrible and blind other road users! Glad the old bill are cracking down on it!
As above, if you're doing it, do it properly with 172/182 xenon units.
If you're after just the white/blue light look, get MTEC cosmos blue bulbs. You wont get done for them, wont fail MOT and wont blind other road users. Win win IMO.
I'm not sure that's true, re. the wash and levelling info. They're not required but if they're fitted they must work. That's what I've picked up anyway.
Correct for MOT, but that doesn't mean they're legal. They're technically illegal but unlikely to be picked up on as the car's still roadworthy.
I'm glad I've got CS trained well.
I don't see as many tools with HIDs as I used to but when I do they get full beam.
