fitting lightened flywheel
mine was fine using that method....also used screwdriver in the flywheel in the past
did you get the ECU ok mate?
i'd threadlock, 55Nm isn't very tight.
a very light smear of sealent on the crank seal wont hurt and may help it slide in easier (lubrication)
thats why they recommend new bolts. Flywheel bolts are normally stretch bolts.
Edit - sounds silly, but you are tightening progressively round all the bolts right?
