fitting magnex decat to valver
hi ive got a magnex exhaust and ive just brough a secondhand magnex decat
how dose the big flangy bit on the decat sit on to the down pipe flange??
anyone shed any light
thanks
jaimie
dont get ya?
to fit it its 4 bolts to undo then put on a new gasket either end or some RED gasket sealant then tighten em up
The flanges will go either way round
no on the magnex decat it has a wide opening on the downpipe side that stops the flange coming off of the pipe as the flange isnt fixed.
if you look at the magnex website at decats there is a pic of what i mean
cheers
jaimie
ah yeah i saw that on the pic, im not sure but thats why i never bought it!!
maybe its like that for universal fitting, ie willy, valver and rsi, u might need an adpater??
thanks
jaimie
Flange
heheheheheheheh
Sorry mate, see what you mean. I got one that is just solid. Prob as ivegotta said, its to adapt to different models, i know the willy has a diferent angle clamp to the 16v on one end. should just bolt up.
Its a bit of a pissed up design mate, i had to do the following on mine:
For a start you need some RTV silicone to form the gasket seal between the flange and the manifold, also i found that the bolt holes didnt line up properly and were at a propper pissed up angle!
I ended up sloting the holes on my manifold flange to get the bolts parrallel, also use a fair amount of silicone on the joint.. as you tighten the de-cat to the manifold it pulls itself square by that olive jobbie!
If you want anymore help mate give me a PM, all in all i wasnt too impressed with the design esp. from a magnex :cry:
