fitting my sub
Car  corsa ecoflex
ok so i know to take the power lead through the bonnet catch gromet but how the hell do you undo the carpet trim along the doors to pull the carpet up????and where do you earth the amp????
i watched my bf do this..
you need to lift the plastic seal at the edge of the carpet.. it will pull straight out, you should then be able to see a bunch of wires underneath.
i hope that is right.. :)
yeh that right, run the power down passangerside and rca's down driverside if possable then it doesnt distort the music. you can earth you ampy on the back of you lights. undo the bolt things put the earth on then reattach the light. thats what ive done
