Fitting rear strut...should be simple! Help please :)
Car  182 cup / Audi s3 8L
Hi all,
I maybe being slightly special here so apologies if thats the case. However, the two nuts that you undo to fit the rear strut just seemed to be spinning and not undoing at all. I thought that fitting the rear strut was a a case of undoing the two nuts, slotting the strut over the threads that are on show and tightening the nuts up again...is this not the case? Any help much appreciated!
Waste of time fitting it, it wont do anything, otherwise do what danny said.
currently only being fitted to run my harnesses off as from everything ive read the eyes aren't safe, and right now i cant afford a cage. from people ive spoken to its safer to get the harnesses higher up so they run more level so when you have any impact the strain is taken by the harness not the seat....dnt tell me thats the worst idea in the world....
Mate I can assure you that bolting it to the strut bar is a big no no! Two little nuts are not going to protect you in a crash and that brace will rip straight up. Bolt the harnesses down to the isofix mounts.
And you think that's safer, do you know how much force will be put on that small strut in an accident?
Put the spanners down an leave it to a professional
f**king hell, such a stupid idea.
Rear strut braces work a lot better if you put them on without the rubber bits that go over the thread of the shock. Lol at using it fur harnesses
