fitting sparkplugs!
take the plenium off and the throttle body under there. make sure you replace them with the correct NGK plugs they are £30 each from renault
30ukp??? No way, Ktec quoted me 12ukp each.
Plug change is easy, remove the induction pipe, unplug one side of the lead on top. Then remove the inlet manifold and whatever plugs that connected to. Unplug the lead, and you can change it. Just make sure all 4 leads are back into correct order.
