Fitting The Magnex System Properly
  Turbo'd MX-5 MK4
  Clio 172mk2
also remember if its a mk2 clio with this zorst u need to cut the small sleeve down about 5cm off mine or else the system will catch on the heat sheilds.
Do you have any pics of the halfords rubber an how the exhaust hangs below the car with the nuw rubbers
Yesterday i bought myself a magnex oval for my 172 mk2
  Clio 172mk2
well yer old zorst might need cutting to get out cos its bent around a bar ,
the small sleave about 20cm long the bit that goes onto the back of the cat, cut that down some sday 10mm i got powerflow to do mine they took about 5cm off it, then welded it instead of the clamp
http://forum.cliosport.net/display_topic_threads.asp?ForumID=6&TopicID=176737&ReturnPage=&PagePosition=1&ThreadPage=1http://forum.cliosport.net/display_topic_threads.asp?ForumID=6&TopicID=176737&ReturnPage=&PagePosition=1&ThreadPage=1
another link all about it
pic not of mine but should give u some idea
http://i5.photobucket.com/albums/y164/jpmad4it/DSC00107.jpg
