Floor Pans
Car  AstraVan Sportive
Does anyone know if the Floor pan is the same on all clios 98 onwards
I.e. would a Subframe for a 98 clio still have the same mountings in a 182
might not actually. as the 182 doesnt have a tyre well iirc. as such it might be different on the back section. the cabin subframe mounting points should be the same for seats as they have the same holes drilled through the chassis to the underside.
Middo the subframe (I'm assuming this this tense) refers to the front engine subframe ie what the suspension is bolted to.
If so them yes it should do the later cars shame a common subframe. A 98 to 182 frame might need the greabox mounts drilling so the extra gearbox to subframe mount will fit but it should be a direct (almost ) fit.
