Fog light on again when braking
ADS_V6
  172 cup clio v6 st
hi yes i know covered a million times,after searching the threads i cleaned the rear light clusters and this worked for a bit,now its come back i put a new rear light on from renault and tday still light on when braking or selecting reverse any help thanks ?
Mine started doing this now and again..
I cleaned up the bulb holders and made the connections excellent and refitted..
It now does it a lot more and when indicating looks ridiculous.. I guess its the wiring connections themselves
  2014 Clio 200t edc
I had this, look at the earth connector (female in light cluster) and twist it slightly with pliers.
I assure you it worked for me.
I am so going to do this ASAP.. looks awful when indicating and the lights are on.. reminds me of an old car with disco lights :(
I cleaned the plugs out with some blue roll and a small electrical screwdriver so come to think of it.. perhaps I bent the connection a bit.. ?!
  172 Ph1/Scooby MY00
Did it sort it?
I am so going to do this ASAP.. looks awful when indicating and the lights are on.. reminds me of an old car with disco lights 😧
MRBILLYUK
  FF Jeden Osiem Dwa
Mine does this from time to time when its wet/ damp weather , so must be causing some shorting problem . The connectors are like new , no corrosion . I took off the light clusters , dried any moisture out off the connection block with a hair drier then liberally coated the connectors with WD40 , problem solved .
