Fog Light Wiring
  Audi TT 3.2 V6
hi, ive just fitted some fog lights for display as much as anything however i was thinking it would be good if i could get them working. I understand its not really possible to do them oem as id need to install relays etc, however what i was thinking of doing is
Ignition Live to switch (so if i forget to turn them of the battery wont die)
switch live to fog light wiring loom live cable
fog light wiring loom ground cable to chasis
and obv would stick a fuse or 2 in there.
question is...where can i get an ignition live with enough power to run fog lights?
  Audi TT 3.2 V6
or would i be better getting a
perm 12feed into a relay
take an igntion feed into the relay
relay to load
relay to switch?
that way the perm feed is from the battery and i could stick it on some old amp cable i have lying around
  Audi TT 3.2 V6
ive been told previously that putting a stalk on wont do the job? else i would like to do it oem ideally
-KarL-
well when i took my bumper off all the wiring is there for the fog lights and been told you only need the stalk
  Audi TT 3.2 V6
yeah my wiring is there already to, might investigate 2mora see where the wiring runs
