Fog lights not working
Car  Writen off dci 100
hi all
as above really, its not the bulbs or the fuse. does anyone know of any common faults with the fog lights
please help
oh its on a 53 172cup
Blown the bulbs ! too much driving about like a charver
;) replace them with brake cooling ducts :D
lol i dont use my fogs
i just needed them the other day and i noticed they weren't working so i changed them bulbs, still not working and the fuse is fine
im stuck
iv just checked if there is any voltage going to the bulbs
i make it just over 10 volts
i have absolutely no idea whats going on
please help
probably rusty connections and build of of white salt on connections.
take them out - try some sand paper on connections to rough them up and remove scale.
or try a voltmeter on the terminals to see if you have a voltage.
Have you ever used them? (sorry if thats a stupid quastion)
yes lol
iv tried that im getting 10 volts is that engough
plus iv tried 2 new bulbs which iv also tested but still no luck
yes lol
Ye sorry bout that question, its just where you said before you don't use them i thought maybe you hadn't realised that the headlights on the stalk needed to be in the sidelight or lights on position before the fogs come on!
same happened to mine when i brought it just used sum wet and dry and cleaned the connections up now they work fine
Hi there i got a clio sport 172 phaseI my front fog lights stopped working so i changed the bulbs they still don't work so i changed the fuse for them they still don't work any Ideas?Cheers
It'll be the connections as they are exposed to the elements abit. Take the connectors off and give them a clean as said above.
