Fog lights not working
Car  mk1 Octavia VRS
Bit of background:
*Car is a 2003 Clio 172
*Has ph1 indicator stalk fitted with horn button on the end. Everything else on the stalk works apart from the fog lights
*Fog lights did work when I first fitted the stalk
*Both front and rear fogs don't work
*I've cleaned all the contacts on the rear lights which cured my flickering fog light on the dash when braking
Any suggestions? Is there a separate fuse for fog lights?
You have a relay under glove box for front fog light, And fuse for front and back fog light.
The light on the dash is working?
Lights on dash were working. Lights worked again briefly after my last trackday but have since stopped again. I need to fix the self cancelling indicator so will check the condition of the connectors on the stalk and give them a spray when I re-fit everything.
If light on desh is on, i think it connection problem some where.
Check the ground wiring.
