fog lights, PH1 MK2, Gromets?
LB197
Looking to wire in some fog lights, does anyone know where any free, or the best gromets are to wire the button into the dash?, or do i need to drill a hole.
Thanks, Luke
Hi thanks for the replies, I had the genuine fogs and genuine wire that connects them up so drilled a hole through to the engine bay with a grommet then threaded the wires over to the little panel next to the steering wheel with the light leveling switch, everything is grounded just gotta finish everything of in the morning
If anyone is wondering I used the RING accessory wiring kit. You can get them on eBay or local car shop for around £13. Takes a bit of fiddling and my dad had to do it.
The standard loom is there ready to wire fogs right in. Behind bumper under the headlight.
