Fried Motherboard?? HELP!
Car  Clio 197
I've got a K7 motherboard.
I uninstalled my old 40GB HDD, to install a new 400GB HDD.
The drive was recognised by the BIOS, but Windows failed to recognise it once booted-up on the primary master.
I was tinkering with BIOS settings, when I got an error message... now the computer won't even startup.
I've reset the CMOS, and nothing has changed. All power is going to the MO-BO, but the screen is black, and I get a delayed beeping sound every 10 seconds.
Is it fried?
I'm probably wrong , somebody correct me if i am . I had a similar problem a while ago , a series of beeps a few seconds apart . It could either be your memory fcuked up , or could be your memory not seated right .If yu've got more than 1 stick of memory you could try leaving one in and checking if one of the sticks of memory is bad , a bit of trial n error .
Did you try putting your old 40gb hd back in and seeing if it boots up ?
Nope... I just disconnected the new one, to see if the primary master booted-up.
As it is, there's nothing on the screen - just a black screen, and a beeping MO-BO.
I'll try the memory, stdby.
Yay.. it's working. :)
Ok, now how on earth do I get windows to recognise my 400 GB HDD?
BIOS knows it's there, but windows dowesn't. :s
Control panel > Adminastrative tools > Computer Management > Disk Management
The new HD should show up and you'll have to set it as active.
