If they've both stopped working then it must either be a blockage in the line between the reservoir and the pump, or before the line splits for front and back. My bet would be the pump though. They have a tendancy of failing.
Try disconnecting the line out of the pump and see if anything is pumped out / if the pump makes any noise.
If it's not that then the wire may have come loose or the seals perhaps.
