How on earth do you do it up!!
Had it off randomly to be powder coated with a load of other bits. Went to re fit it yesterday but gave up after a few hours and with the lack of light.
I've got the ARB in position with the powerflex bushes and brackets in place. Bracket is hooked on the link, but I just cannot clamp the bracket up to the chassis.
The bush needs so much more compression that I can manage just to line the bolt holes up. The Renault bolt is no where near long enough to try and close the gap. Currently starting at about an inch and a half down to a cm when I've used a longer screw to try and clamp it up.
Hoping someone might have some advice or some special techniques to tell me to help me out because I just cannot see how it's possible.
I'm also thinking that the poweder coating of the bar and the bracket may have just been that few extra mm too many. So might look to file the insides of the bushes down a bit.
Any advise will be greatly appreciated.
