Front camber adjustment. Clio 172.
Bankrupt_drunk
  Clio 172
I've just come back from a geo check after changing the suspension to cup spec, getting rid of the cheap lowering springs thst came with the car and putting some new track rod ends on.
Most of the dimensions are within spec, but the front camber is off.
Does this matter?
If so, are there any camber shims/bolts/plates around that can adjust this?
Brigsy
  T.Turbo
Camber bolts, or elongate the bolt holes on the strut to suit required camber.
