front camber help!
TRH_Racing
South East - Herts/London
Is it worth having if im gonna be doing the odd track days / autosolo's ? i think ones at .3 and the other is .7 .. i have been debating getting them both set to 1.5degree's but im not sure if i should!
Yes, you'll muller the outside edges of the front tyres where they are at the moment. About 1.5-2 should be ok depending on how often you venture on track and how hard you drive on the road.
Mine is about 2.25 deg camber and the tyres are not wearing on the inside and I do use mine on the road as well as on track.
Out of interest where are you getting it set up? Might be useful for me as I'm not a million miles from you.
i have friends who work at a exhaust / tyre place that does tracking, they're bloody good, i've always gone there but i might go to a specialist instead, they're in Little chalfont in buckinghamshire
ill see how much i can get on there with out bolts and shims etc, 2 sounds pretty extreme haha
-1.75 is all you'll get from many camber bolts. A Ford focus runs -1 so you'll be fine with -1.5. The rear is around the -1.3 Mark.
