Front discs
Car  Clio 182
needing to change my front discs shortly before its MOT, what do u guys recommend;
Brembo HC for £60
or
Renault Original discs for £100
obviously the brembo ones are cheaper, are they as good as the standard discs??
cheers :D
Yep go for the brembos, they'll be better than standard discs. Especially when paired with some decent pads.
good good, cheers lads, i've got Greenstuff pads on already so they should pair up fine!
Should be using new pads with new discs. I've got hc fronts with greenstuff pads and they hold up to the abuse I give them, braided lines are one of the best £40s i've spent too.
I have sum worn front disks for sale.
£30 posted
I will mesure thinkneess 2mz m8t
Just thort I would let you now.
Si
