Front fogs dead - relay
Front fogs have decided to pack in, dash light comes on ok, rear fogs are working fine and the fuse is ok, both lights are out so its not the bulbs. I hear a click (like a relay) near the glovebox when I switch the back fogs on, but no click when the fronts are switched on. Is there a relay for the fronts, anyone know where it lives?
If u dont hear a click in the fuse box down by the passenger seat, then the relay is blown. There is a relay for both front and rear fogs.
In which case replace it, its the second relay from the right on the row of 5/6 relays/relay slots. Check in the Haynes for its location if unsure.
Although relays are hard to blow, the fuse for the front fogs is located in the left housing under the swing lid, where the windscreen washer tank is, inside the the engine bay. Check to see if that has blown.
