Front passenger side wheel arch
Car  Clio Sport 182
Hello, recently purchased a 182 and upon inspection found out that the previous owner had the car repainted and in doing so took apart the front bumper, and didn't put it back together properly. So now I've been driving it (only for a week) and the front passenger side wheel arch (inside liner) has fallen apart gradually and been partially damaged. So I now need a to find a new arch liner. Any suggestions please?
I’ve got these in the shed, problem is one has been cut but I don’t know which is which.
also I’m bleeding miles away from you.
also I’m bleeding miles away from you.View attachment 1491477
Thank you, but I've now been told it's the front 'front lower' wheel arch liner. There's a lot of discrepancy over what part is correct for the 182 and its not easy trying to find a replace part. The part number has annoyingly been worn away. Think I'll have to go to Renault specialist unless anyone on here has any idea where I can get the part from.
You can still buy them new from renault. They are around £50 for each part.
Post a pic of what part it is you are missing as im sure more can help, based on that.
I went to a Renault specialist today and they gave me the part number '6000073747'. I've attached photos of the part I need too.
as above, available new still from Renault parts direct, you want item number 2 on the diagram, NSF
Am I right in thinking mk2 arch liners aren’t available anymore? 😬
Any other good places to get them from if that’s the case?
