FRONT SUBFRAME
Car  phase 1 flamer 172
Bought what was advertised as a 182 cup subframe. I have noticed that the rear mounting holes, last one either side for the wishbones is larger than the other ones. Is this normal or have they been possibly drilled out for some reason? Thank you.
The case was solved on Dec 22, 2010 new genuine Renault sub frame wishbone mounting holes at the rear of the sub frame are indeed larger than the others.
http://www.cliosport.net/threads/su...n-arm-hole-wear-check-your-clio.368939/page-4
I am guessing you forgot about replying to that thread.
