Can anyone tell me where is the fuel pump & fuel line located on a 172 engine? Thanks
B BaBOo Oct 18, 2003 #1 Can anyone tell me where is the fuel pump & fuel line located on a 172 engine? Thanks
M maff Oct 18, 2003 #2 under the rear seat (drivers side), pull the rubber bit open and you can get to the fuel pump there. Im pretty sure that is where it is anyway.
B BaBOo Oct 18, 2003 #3 I mean the rubber pipe supplying the fuel to the engine near the injectors Thanks!
BenR Oct 18, 2003 #4 its attatched to the end of the fuel rail under the inlet manifold................you cant miss it. Its non return and the regulator is on the pump.
