fuel pump question
Car  clio rs 2000
i think i have a small problem with my fuel pump and some times the car shakes like the fuel comes low sometimes it goes well
i want to change my pump with walbro 255 lph gss-341 becouse the oem part is so expensive and you have the change the whole pump
can it make any problems if i use this pump
and someone say that the pumps are same in all clios 1.2 -2.0 is it true
Why jump straight to the pump? have you checked other things like fuel lines and the filter?...
That's what i'd do, process of elimation :P
Can you smell petrol?
i have checked injectors at bosch service ..no problem
new spark plugs ngk pfr6e-10
use a different ignition coil and noting changed
use a different tdc sensor and noting changed
cleaned all the inlet manifold and filters
and no faults apear on clip
i think the last think is fuel pump
although we have checked but maybe the ht leads
yeah the 16v petrol mk2 clio's all use the same in tank fuel pump.
