Aerodynamics
Drag Co-efficient/Area (Cd/A)
0.35
Body Type
No. of Doors
3
Body Type Classification
Hatchback
Drivetrain
Number of Forward Gears
5
Gearbox Code
JB1
Vehicle Speeds (mph) - 1st @ 1,000 rpm
4.7
Vehicle Speeds (mph) - 2nd @ 1,000 rpm
8.4
Vehicle Speeds (mph) - 3rd @ 1,000 rpm
11.9
Vehicle Speeds (mph) - 4th @ 1,000 rpm
15.3
Vehicle Speeds (mph) - 5th @ 1,000 rpm
19.2
Vehicle Speeds (mph) - 6th @ 1,000 rpm
Not Applicable
Gearbox Type
Manual Gearbox
Capacities
Fuel Tank - Litres (Gallons)
50
Fuel Consumption
CO2 (g/km)
139
Urban - mpg (litres/100km)
36.2 (7.8)
Extra Urban - mpg (litres/100km)
57.6 (4.9)
Combined - mpg (litres/100km)
47.9 (5.9)
Steering
Turning Circle Between Kerbs/Walls (m)
10.3/10.7
Number of Turns (Lock to Lock)
3,4
Braking
Front Disks (Diameter mm)
259
Rear Disks (Diameter mm)
203 - Rear Drum
Engine
Fuel Type
Unleaded Petrol
Injection Type
Multipoint Injection
No. of Cylinders
4
No. of Valves
16
Induction Capacity (cc)
1149
Bore x Stroke
69 x 76.8
Compression Ratio
9.6:1
Maximum Power - hp DIN (kw ISO)
55(75)
Maximum Power (revs/min)
5500
Maximum Torque - Nm ISO (mkg DIN)
105
Maximum Torque (revs/min)
3500
Performance
0-62mph (0-100kph)
13.0
Maximum Speed - mph (kph)
106 (170)
Tyres
Wheel Size
5,5 J 14
Size/Profile
175 / 65 R 14
Transmission
Wheels Driven
Front Wheel Drive
Seating
No. of Seats
5
Vehicle Type Number
CB05EF
Dimensions (mm)
(A) Wheelbase
2472
(B) Overall Length
3811
(C) Front Overhang
739
(D) Rear Overhang
600
(E) Front Track
1406
(F) Rear Track
1386
(G1) Overall Width (Including Door Mirrors)
1930
(H) Unladen Height
1437
(H3) Height with Open Tailgate
1929
(J) Unladen Platform Height
651
(K) Ground Clearance
>120
(M) Interior Elbow Cabin Width - Front
1370
(M1) Interior Elbow Cabin Width - Rear
1440
(Y) Maximum Load Entry Width (Upper Entry Width)
906
(Y1) Maximum Load Entry Width (Floor Level)
941
(Z) Height of Rear Opening
635
(Z1) Load Area Length with Rear Seats Folded
1345
(Z2) Load Area Length
624
Weights
Kerb Weight (Excluding Driver) (kg)
1020
Gross Vehicle Weight (kg)
1490
Gross Train Weight (kg)
2300
Maximum Towing Weight Braked - Driver Only (kg)
1150
Maximum Towing Weight Unbraked - Driver Only (kg)
510
Volume
Minimum Load Volume (Litres or m3)
252
Maximum Load Volume (Litres or m3)
595
http://www.renault.co.uk/RenaultSITe/puma/GB/PROD_GB/MEL_PROD/en/Clio_cl2/r6/s2/p1.jsp?BV_SessionID=@@@@1692682925.1072539723@@@@&BV_EngineID=ccceadckfhekmffcfngcfkmdfkjdfmf.0&cc=2&sec=Version&type=VP target=_new width=600 height=400">
