Fuses blowing and rear clusters all flashing together!
Paddy_g46
i bought a hybrid yesterday and basically im getting electrical problems fuses blowing for the brakes repeatedly and the rear clusters acting funny like when u brake and indicate they both flash! i removed the unit and it had quite a bit fo water in so i dry it out but its still doing it on certain combinations of lamp! what can any1 suggest?
Gaz_
  Extreme mode
Check and clean all connections, sounds like earthing/poor connections imo ;)
Clean up contacts with some wire wool or sandpaper etc, then give it a good blast with some switch contact cleaner. Also if there are any earth straps in the boot, check that have good clean connections with the body.
Gaz_
  Extreme mode
re-do that, but for the rear clusters, 9 times out of 10 its a bad/high resistance connection. As i said just give them all a slight clean up with sandpaper and refit :)
Paddy_g46
ok mate i have a spare set in the garage so i think ill replace the insides of the clucters
we gonna ave a any pics of this beast?:evil:
pics of the beast will be up very soon!
