timsclio172 said:your gonna get some serious tyre wear with toe out and 2 degrees of camber - be getting some tyres again in a couple of months!
had mine set up last week - I was told 2 degrees of camber is way to much for a road car and will make the front end too twitchy on the straights. Also when running a lot of camber toe in is advisable to stop the tyres having a pasting
Donz144 said:Well Ed my dream pipeline includes: High Torque Cams, Manifold match,
Donz144 said:have you had the angel works treatment? I thought it was best to get the set up right first then add the real grunt!
rmccardal said:I have an AngelWorks flowed Head, full manifold work and some pretty wild cams. I'd stick with his High Torque variety though unless you want to go standalone management.
I have ledas too, what spring rates did you get and what damper settings are you running ?
Dansta said:ill remember that the next time i look at a RenaultSport cup racer...they come out of the factory like this dont they?
I know these are track cars not road cars, but surely he's trying to get as close to a track/handling setup as poss.
Dansta said:id o say that, but simply as i assume he's paying all his cash and intends on some track action? hence he's tryin to get as close to Track setup as poss?
Also, i always thought LEDA's used rear coilovers, my bad.
Dash said:My Ledas have a special A127 setting.![]()
Alan said:Have you driven an F1 car before?
