gear gaitor coming away (ph2 172)
d6n
  Ph2 172
the gaitor is loose all around the base and when i go in reverse it comes out the hole?
the clip around it is stapled to the gaitor so does in need a new gaitor and clip?
i.e do they come as a unit?
As above really. I just glued mine because I couldn't be arsed going to Renault to buy a new one.
  Petrol Blue Clio182FF
I have the same problem, what glue did you use? I've glued mine twice now and it doesn't last more than a couple of months. I used epoxy resin and prepared both surfaces beforehand.
