Trying to fit the selector seal kit , I'm stuck because the selector ball joint and its housing are stuck in the car.
For illustration , this part is stuck in the car , the white plastic cannot be removed : http://i.ebayimg.com/images/i/251974257417-0-1/s-l1000.jpg
I need to replace the white bush anyway so I tried to brake it with a screwdriver and a hammer but still no joy .
Any ideas except towing the car to a garage and wasting a day at work ?
BTW is draining from the 16mm bolt that holds the neutral spring good enough ? the 8mm square one is too tight.
