gear trouble
my clutch went in my car, lifted the engine the clutch was in four pieces fitted a new bb one loads of other bits now still having the same trouble clunky sometimes when changing gear and sometimes grinds especially when taking the revs to 6k+,
Any ideas?????
Why would the flywheel cause a problem? Exactly it wouldnt.
Your probably beating the synchro so it will crunch. Check the oillevel and use some decent oil in the box.
Other than that cable or pedal or dont change gear like an arse.
If the car is ticking over put the clutch down everything is ok put then go for a gear and the car shunts as it is engaged new cable, new pedal and new clutch 70 mile ago, think the box might be dying its done 110k the box with a bit of a hard life
