I have an issue whete the vertical arm (one that leaks at the seal) in the gearbox is sticking when selecting first, second and reverse,up position at the box.
Reverse is very hard, have to push the lever over and select, I've disconnected the linkage to rule that out and confirm that the arm itself is sticking in position within the box, it takes a good pull to deselect.
All gears work with no crunches etc, I covered 300mile or so yesterday and it was fine, had it flat out on a little stretch in fifth at the end and the problem arose after that when coming to a roundabout and trying to select second,I'm fairly certain something inside the box on the arm has came loose/detached, anyone had this issue?
Where's best to send box if it requires repaired, was thinking Pure Motorsport?
