give me please a price for the megane block + gearbox .well i have a block and a NEW box, you can have them both cheap if you can sort out the shipping side of things
nice work and thanks for posting! Only i have one big issue: i want to use the original management but then i need te original flywheel....
Edit: do you have drawing of the adapter plate? (Y)
I will speak to the owner and ask him. and yes, it will be a hydraulic clutchAnd can you post it or send it to my E-mail?
Edit:
Did you convert the clio to hyd. Clutch?
so how have you spaced the flywheel out then? im running an omex managment so this would mean me needing a trigger wheel on the other side of the block bolted to the crank pulley? then id need to position the sensor at TDC (which is a task in itself)?
i know but did i say it's on a small budget? i want to re-enforce the end of the housing so that the 2 axles wont split the gearbox housing and also a sper-diff so the diff wont collapse (and i get the grip i need)
just don't fancy to make driveshafts, mounts, adapter plate, motormanagement due to an other flywheel etc.
There isnt much you can do with a JC5 box on a budget. It's the reason i and many other people decided to go the VAG route when doing conversions. The Renault tackle just isnt up to it.
You mean Reinier, cannonballman on RTC.
I know he does that but i read negative stories on all forums. Dutch included.
Edit: not with Reinier but just jc/jb boxes
The only way to go seems to be a vag box. The problem is that it needs a lot of modifications like driveshafts etc.
The next problem is i will need to use a stand alone management while i was planning to use the original management...
