gearbox help?!?
Car  RenaultSport clio 172 mk2
does anyone know what the difference between a jcs129 and jcs130 is?
Also, if i currently have a 130, will the 129 fit?
Its a 2002 sport 172 that i have, many thanks for your help
The JC5130 is the 182 gearbox, which means it reads the speedo from the ABS, what you need to do is have a look at the back of the engine bay, where both driveshafts go in and see on the top of the diff housing is there is a sensor going in. if there is then no the 130 wont fit.
ive been told i have the 130 now when i rang renault parts and gave them the reg
The JC5 129 was from the mk1 172 and the cups iirc, the ones with the mechanical speedo, probabily easier to ahve a look at teh arse end of tyhe box and see if there is a speedo cable there
JC3 130 was the Mk2 phase 1 gearbox. it has a speedo output on it.
JC5 129 was fitted to the cup and the normal 172 full fat phase 2 the cup is a specal box as it has its speedo output on it whereas the normal car uses the abs system.
